2006-02-16 06:17 PM - last edited on 2023-05-25 06:19 PM by Rubia Torres
2006-02-17 11:34 PM
Karl wrote:I think the idea was to have ONE skin or material that would be changeable, which would be the "existing" wall and would be adjustable to conditions in field. However, I think Daniel might be onto something.s2art wrote:Not me. (I'm not sure what it would mean to vary the width of a composite?...)
Wouldn't it be nice if you could have variable widths for your composite walls? Adjust the widths in wall settings instead of in Composites......
Anybody care to make a wish? (for AC11?)
Daniel wrote:Though I can't think of how this would be implemented (would walls just "snap" together, would there be a setting,... ), I think this would at least solve some of the issues.
I think what we really need is a unify wall comand, maybe I'm crazy.. but that just makes sense to me.
2006-02-19 09:47 PM
Karl wrote:I'm not saying do away with composites, just have the settings in the Wall tool instead of as a separate entity. By combining them this way you could have walls with the same skins, but be able to set the thickness of particular skins individually for each wall if necessary instead of having to create another composite.
Not me. (I'm not sure what it would mean to vary the width of a composite? The skins presumably correspond to some actual materials. Which skin(s) would you thicken/shrink and how would that be interpretted?)
Again, I don't understand what variable widths could mean (or depths for slabs/roofs) in a real-material sense?
Karl
2006-02-19 09:48 PM
Daniel wrote:This is already (partly) available. A selection of connected walls will behave like a polyline (or polygon if closed). The only difference is that unify would allow single click selection.
cheers,
dan
2006-02-21 09:32 PM
Matthew wrote:How is this again? Is this different from the "Group" command? Can't say I've ever seen or heard of this before.
2006-08-08 10:28 AM
Sergio wrote:I'm having similar problems, and windows/doors that would cut a hole through more than one wall would solve most of my problems.
Another option would be for the windows/doors to be able to "span" two walls
