2023-01-24
11:21 AM
- last edited
3 weeks ago
Molinda Prey
I am having an issue with elements not showing in section view. All the solutions provided in posts I have see don't seem to fix the issue.
I have checked:
Renovation filters
Layer combinations
Any ideas?
Thanks
2023-01-24 11:30 AM
Which elements aren't showing? Have you checked Model View Options? Which version of Archicad are you using and on which OS?
2023-01-24 11:45 AM
I'm using Archicad 24 student edition - Windows 11 Pro (21H2)
Its a number of elements - Columns, stairs, plumbing fittings, some exterior walls
2023-01-24 12:00 PM
I have checked the model views and they seem ok.
Please see attached the floor plan and the section incase they help in any way.
2023-01-24 12:01 PM
Have you tried turning all layers on to visible. I know you mentioned you had checked layer combinations but it would be worth a try. It would be useful to post some screenshots of the section, the section settings and a 3D view to see if the elements appear there.
2023-01-24 12:02 PM - edited 2023-01-24 12:03 PM
Is the section set to zero depth in the section settings? If it is try setting it to infinite or set depth.
2023-01-25 02:30 PM - edited 2023-01-25 02:32 PM
Any chance you'd be willing to share the model? It does look like a zero depth section. You may be right Lee.
