Elevation view - How to disable glass transparency in S/E?
Hello.
Hopefully someone can help me with this rather annoying problem. Ever since I set glass (material) to transparent in 3D, all windows became transparent in S/E views too.
Seems obvious, but I need clean S/E view sets, and currently all my S/E sets display internal doors, windows on opposite external walls, and so on.
Unfortunately, limited horizontal rage of S/E isn't appliable in this case.
Is there a simple way of disabling (glass) transparency in S/E?
7 REPLIES 7
You can do this by changing the setting in the 3D Window Settings dialog and then reset the View Settings. Hopefully this will be added directly to the view settings themselves soon. It save trouble of course to make sure this is set before you create the views.
Oh, how on earth could I have missed that? Sometimes one can't see the forest for all the trees.
Thank you.
mm..sorry.. but can i just disable transparency in S/E ? or we are talking about changing the settings for section ? " disable materials own color and 3D vectorial hatching? "
whatever
transparency is set in the 3D window settings, and is remembered with your saved view. Materials own colours and fills / hatching are settings within the Section / Elevation itself. Personally I think these should be able to be set and remembered in views too.
s2art wrote:
whatever
ok!!
Rafal SLEK
In AC11 transparency for sections are separated. At last...
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
Djordje
.. and the transparency is set as a parameter of the S/E marker. Also, it is saved with the view.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
