2008-10-09 08:40 PM - last edited on 2023-05-26 12:21 PM by Rubia Torres
2008-10-09 08:48 PM
2008-10-09 09:09 PM
Rick wrote:I found an old .prf file from when I first loaded archicad and set up stuff with the guy who initially taught me. It hasn't been updated since though. Is there a way to save all of the favorites I have made so far? What I have always done (since I didn't know a better way) when I started a new drawing was to save an old one and erase the old stuff and start over so I always had the favorites.
It's good to know where you are saving the favorite file to. It is a ".prf" file, so you might can search your HD for it. You are saving it.. right? Best to dedicate a place to keep it (them). You should be able to send them the .prf file, and with the same library they should be able to pull up the same thing. I have done that without any problems. They will need to manually load the right prf. file.
2008-10-09 09:25 PM
2008-10-09 10:04 PM
2008-10-09 11:00 PM
HAL9000 wrote:How do I save as an .pla file?
You might want to try sending the file as a .pla (archive) rather then a .pln
2008-10-09 11:18 PM
2008-10-09 11:21 PM
