Grey Materials - Graphic Override
thais2023
Hello everyone,
I am trying though graphic override to adjust a floor plan to make the materials fills (hatches) as per the image to be in a certain pen (grey), but all the ways I try it creates a solid grey hatch on top, not just changing colour, I can't change the pen set and had an impression that saw something similar somewhere. Thanks
Guru
In your Graphic Override Rules, uncheck the Fill Type box. By the sounds of it, you only want the Fill Foreground Pen.
Ling.
ps. Since you are talking about Graphic Overrides it would be a good idea to include an image of your current settings. You should also include some information about your computer setup in your Forum Signature. See mine for more info.
Win10 | R5 2600 | 16GB | GTX1660
Hi Ling, thanks so much, it worked.
