SOLVED!
How to Build a Car Ramp Cover Ramp
Rayfoo Lee
I tried to build a ramp using a deformer and then tried to give it a material, but the idea didn't quite work out.捕获.PNG
2 ACCEPTED SOLUTIONS
Solution
Marc H
There are ramp objects (straight and spiral) for parking structures.  They work well and include transition grades.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Solution
Eduardo Rolon
You can also use a single plane roof.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
2 REPLIES 2
Solution
Marc H
Solution
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
