yesterday - last edited 4 hours ago by Barry Kelly
I created a custom door using walls and slabs, and saving the selection as a door. However, because its custom, the Description panel is not there, d therefore I can't put in information for it to appear in the Door Schedule.
4 hours ago
Saving selection as a custom door will give you a basic, non-parametric door object.
You would have to edit the object scripts and add all of the parameters you want if you really need them.
an hour ago - last edited an hour ago
There is a macro you can add that should give all of that to you, so the amendment of a single CALL. I do not have access to AC atm, but will check back later if no one else has dug it up by then.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
