2018-09-19
06:43 PM
- last edited on
2023-05-25
04:41 PM
by
Rubia Torres
Solved! Go to Solution.
2018-09-21 05:58 AM
2018-09-20 03:38 AM
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2018-09-20 05:53 PM
Lingwisyer wrote:Thank you for your response. AC22 / macOS High Sierra Late 2012
AC21 / 22? You should add you AC version and some computer specs to your signature for more accurate help.
If you set your reference line to follow each side of the dividing wall, you should get the divided landing by default.
2018-09-21 05:29 AM
2018-09-21 05:42 AM
2018-09-21 05:58 AM
2018-09-21 11:07 PM
2018-09-25 04:22 AM
2018-09-28 11:23 PM
Lingwisyer wrote:You may be right. I just thought it could be an issue because it is based on library objets and Full and Solo Libraries are not the same. ...which I found interesting.
Might it just be that your default stair rules are different to your friends? Solo / full should not make any difference with stairs as they are not related to teamwork or modules...
