2024 Technology Preview Program
I want to change the botom and top offset to 0 after hotlink.
LeeJaeYoung
I accidentally found a hotlink with the wrong story and offset in the elevation, but the location is correct.
What should I do?
Do I have to delete it and do it again?
AC27 on window 11
mija
If the ofset of walls is incorrect you do have to do it again and save as module, and update the current one. As far as story goes, you can move entire module between stories and such.
Archicad 26, build 3001
Montenegro
The hotlink below normally has a value of 0.
There seems to be a problem while copying.
Is it impossible to edit?
AC27 on window 11
