2013-05-13 04:01 PM - last edited on 2023-05-26 11:17 AM by Rubia Torres
2013-05-13 09:19 PM
2013-05-13 09:24 PM
2013-05-14 09:46 PM
2013-05-14 10:56 PM
Stress wrote:
Search Archicad Help for Parameter Transfer Between Objects
You'll be able to "eyedropper" the door with the trim you want and "inject" it's settings into thesettings window dialog boxof your bifold door.
Then you can inject those setting into your existing bifold door.
Keep in mind. You'll have to resize the bifold to it's original width/height.... the trim, panels, etc. will match the original (D1 door).
Make sense?
2013-05-22 02:18 PM
2013-05-22 02:23 PM
2013-05-22 07:06 PM
rob2218 wrote:Rob:
I'll have to pick yer brain on the "step-by-step" on this function..
2013-05-22 07:40 PM
