Injecting the door "trim" settings onto another door type?
rob2218
See attached PNG.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
8 REPLIES 8
rocorona
No.
But you can select different door types at once, or even ALL the doors of the project, and modify only the casing parameters.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
rob2218
bumski...yeah, thought that was the case.
too bad...would be nice (without creating a FAV) to be able to extract the say "trim information" out of a door and simply add it/modify it onto another door......oh well, maybe AC18?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Search Archicad Help for Parameter Transfer Between Objects
You'll be able to "eyedropper" the door with the trim you want and "inject" it's settings into the settings window dialog box of your bifold door.
Then you can inject those setting into your existing bifold door.
Keep in mind. You'll have to resize the bifold to it's original width/height.... the trim, panels, etc. will match the original (D1 door).
Make sense?
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
...makes sense you ask.....yeeeeeah??? maybe?
I'll have to actually "do it" to see how that functions.
GS did teach us once how to do that but I rarely use this functionality that, well....when you need it most is when you've already forgotten about it.
thanks,
Make sense?
i>u
Edgewater, FL!
SOFTWARE VERSION:
I use this all the time. If I have a double hung window with all the settings I want (trim, stool, sill, even pens) I use the eyedropper on the window and open the window dialog box. I can then inject the settings into a casement window, for example. This saves a ton of work.
rob2218
Steve....I'll have to pick yer brain on the "step-by-step" on this function.
I've run across many times just this. I want to copy the "trim,stool, closure type...etc" settings of a certain window BUT I don't want to copy the window type onto the newly created window and I don't want to create 1000 favorites just for the "settings" issues.....so with that said I may just talk to you for a few minutes to discuss.
thanks....yes, this feature would definitely help tremendously in grabbing "certain" windows settings and adhering them to another window type.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
rob2218 wrote:
I'll have to pick yer brain on the "step-by-step" on this function..
Rob:
Watch Eric's Video:
Parameter Transfer
rob2218
wow.....thank you!
I will.
thanks for that find.
RR
i>u
Edgewater, FL!
SOFTWARE VERSION:
