Interior Elevations Zooming
NILAM
I have created a bunch of interior elevations and had zoomed to the current view.  I open view settings and set the zooming to "current zoom" and click ok.  I right click on the same view and open the view setting and the zoom setting is set to "zoomed area."
Why does it keep defaulting to zoomed area?  Is there a way to actually have the view settings save to "current zoom"?
Operating system used: Mac Apple Silicon 14.2.1 Sonoma
That is fine.
It is only 'current' zoom when you reset it.
As you are setting it to the current view on screen.
After that it will be known as the defined 'zoomed' area.
This is normal.
1 REPLY 1
That is fine.
This is normal.
Setup info provided by author
