Monday
This building was modelling in Revit - but I was wondering if this triangular parametric form can be achieve in archicad? I want to create something similar but was wondering if anyone knows an efficient way to do this? I can only think of doing this through morphs
Monday
Grasshopper?
Monday
Hi, as said by @Lingwisyer Grasshopper-Archicad is the right choice, in addition you could give a try to this object:
Responsive facade that interact with grassohopper and returns an unique object instead of a collection of archicad native element
Monday
Manually >> it is just a basic mesh. Choose a grid en set all edges sharp.
With Gdl (and ai) you could make something with a little more control like level of detail and resolution etc...
Monday - last edited Monday
with native Archicad tools? probably yes, but it wouldnt be fun
but still, have a look at a guy at youtube who calls himself ArtTool, who does non conventional geometries using only archicad standard procesess
Thursday
Thanks guys! We ended up using a shaped called curved base as a starting object and then turned it into a morph to edit the points to create the points where we wanted it which is similar to this.
