Lock 3D vectorial hatching
Is there any way to lock the position of a 3D vectorial hatch pattern
relative to the edges of the element that has the hatch pattern asigned
to it's surface ? I have a simple wall with a brick running bond vectorial
hatch pattern on it's surface and that pattern has been aligned with
the vertical edges so that the wall is exactly so many bricks wide.
If I move the wall the hatch pattern no longer aligns with the vertical
edges of the wall. I need some way to lock the pattern so it stays
aligned to the edges of the element.
Thank you,
Peter Devlin
22 REPLIES 22
Eduardo Rolon
… and now I have no idea what we are trying to prove, fix, clear up or complain about.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Thomas Holm
This happens to me all the time! Is it my age? Alzheimer's?
(Sorry for hijacking the topic - I'll stop now)
Hello Link,
You are right about the display of the fill pattern is dependent
on the direction the wall is drawn. I drew two walls one drawn
left to right and the other drawn right to left and set one behind
the other and I am delighted that I could finally reproduce
the "Link effect". I could not see this with a running bond fill
because it was a repeating pattern. Thank you for pointing
this out to me. It is good thing to know. Please see attached.
Peter Devlin
