MORPH Element - Lines in Elevation and 3d
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-08-06
09:16 PM
2023-05-24
07:30 PM
Rubia Torres
MORPH Tool = Awesome
Very powerful.
Baby Steps - Using it to create a few quick stucco details on the fly in 3d.
Problem...
Lines appear at junction of MORPH element and adjacent columns / slabs.
Any ideas?
I have tried changing surface materials. I have tried SEO operations on the MORPH element.
All the nodes are definitely in contact. The lines will just not go away.
I know there are myriad different ways to achieve the arches but wanted to get the MORPH tool working.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-07 03:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-07 06:10 AM
But lines are there in elevations and sketch render (bread and butter renderings for me). Also there in the 3d window, either engine.
What a drag. HELP!!!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-08 08:09 AM
Anybody?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-08 02:49 PM
In this instance, the corner has a column and the walls intersect with the column. Since the column material is the same as the wall material, there should be no line.
As far as your original question, I have encountered the same thing. I either have to deal with the line, or make the Morph element aspect larger, so there is no line.
Hope this helps.
Jeff
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-08 04:50 PM
So it looks like I can't really use the MORPH tool yet as I should be able to.
Really disappointing. Another ArchiCAD tool with an illogical quirk that makes it, well, quirky...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-08 09:26 PM
The morph is great for all the trim doodads, looking forward to seeing your decorations!
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-08 10:09 PM
I agree... the fact that a co-planar, same material morph surface cannot 'join' another surface without a line in elevation is a great disappointment.
Easiest test of the failed functionality: model two walls stacked on top of each other - shows in elevation as a single solid rectangle. Select the top wall, right click and Convert to Morph - the result has a line between the two surfaces.
Bummer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-09 01:34 AM
I just tried the same with slab, roof and wall objects before I saw your post. I tried over sizing the MORPH with a SEO subtract... I've tried everything I can think of.
All the same result.
So is this verified then? Surfaces will not join with MORPH. No work around?
No setting I am missing somewhere...
The MORPH objects are not designed to have surfaces mate cleanly with other types of objects, period. (Except in Lightworks Render)
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-08-09 01:39 AM
Meshes wont cleanly mate surfaces with wall, slab and roof objects...
And meshes wont mate with MORPHs either... Or vice versa, depending on your point of view.
Just saying...
