Magic wand tool not working archicad 26 &27!!
Georgia_Eloise
Hey, I am trying to make a mesh for a site like I normally do using contour lines and adding them to a mesh with the magic wand tool using spacebar, however on both archicad 26 and 27 I am not able to use the magic wand tool. I run MacOS with apple M2 chip and currently with Sonoma 14.3.
Previously when I had this issue, a simple shut down and restart of mac and archicad would solve it, but not anymore.
I have also tried assigning different keys to the magic wand tool, with no success.
Any advice is much appreciated, otherwise I'm looking into trying to learn a new software - which is not going to be fun....or help get my uni project done quickly!
Hi @Georgia_Eloise,
regarding magic wand, you can activate its function by other ways, did you try all ways and nothing working with you?
AC 28 INT 5200/WIN 11
It works fine for me in Archicad 27.
Can you give a specific example when it does not work for you? I tried it with Lines, Circles, Polylines, Splines, both when they are inside the Mesh polygon or when they overlap its boundary, and it works in all cases.
