Model shows Incomlete in layout
Matratzis
Hi, I have an issue and I bet the fix is really easy.
When I try to get a 3d Model view onto my layout the border crops the model. When i change the border to be bigger the model doesn't show completely.
I tried a lot of stuff and couldn't figure out how to get the model to show fully. Let me know if you have an Idea 🙂
Thank you In advance!
Yes, that is what I meant you could try - I couldn't remember the "redefine" part and said rebuild 🙂
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
4 REPLIES 4
CosminF
Hi!
Check if in the view the model is assigned to is partial (it does not show in its entirety). If so, you can either:
1. Rebuild the view based on the 3D Window (with all the elements visible)
2. Delete the view and create a new one.
Further reading, it may help: https://help.graphisoft.com/AC/24/int/_AC24_Help/030_Interaction/030_Interaction-6.htm
Hi!
Sadly have the same issue with all views.
Im loading the 3D window with an isometric view into the layout.
I tried rebuilding the model and it didn't work.
The view gets loaded into the layout cropped like that and even if I move the model in the layout it doesn't load the rest. 
Thanks for your efforts :)!
I got It!
I had to redifine the 3d window with the current view settings.
Thanks for answering 🙂
Setup info provided by author
