Option for Door Casing Width Grayed Out
Bill
I am using door D1 Entrance 15 and the option to change the width of the exterior casing is grayed out (see attached).
What controls this? How do I change it so that I can input a different width casing?
Thanks!
Bill
undefined
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
Bill
I just figured it out myself... if the door is ganged then the option is greyed out/frozen. Don't know why that would control it, but it does.
Bill Szustak RA
In the ganging interface, you have checkboxes for whether the casing is present/ganged or not. I would imagine that the casing has to be visible for its width to change. If you've hidden the casing for one window in a gang - then the casing size would be set by the adjacent window.
AC 28 USA and earlier   â€¢   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
