Questions
Hi, everyone,
Question is, do you know if there is a simple way of calculating the perimeter of all windows in the project?
And i have a big problem with insulation turning. I'm making a model and i want to show two types of facade. Existing one (without insulation) and a renovated one (with insulation). When i set model view on CORE only or Without Finishes, it simply doesn't display the windows correct in facade and plan.
And the last one. For the terrace window-dooor. I want to have a dimension marker for both - window and door, and not the whole window Door? Is it possible?
0 REPLIES 0
