Roof Accessory Tool - Standing Seam
Steve Jepson
Is there a way to control the layout of the standing seams to the match on each side of the ridge?
When the roofs surfaces are the same on each side of a ridge or valley you can just mirror the metal roof, however, if they are a little different that does not work so well.
4 REPLIES 4
Carstenem
You can but it's a bit fiddly .
- moving the roof reference line in 2D moves the 2D display.
- To move the 3D you have to extend/reduce one side of the roof to match the opposite side, then extend/reduce the other side accordingly. ( do this in 3D view )
Help screen shot attached.
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Steve Jepson
Yes. That's what I am doing where I can, modeling the both roofs the same, generate that standing seam metal roof, mirror it, then adjust the one roof and the metal roof with adjust with it. But you can't always use that method. I use other tricks a well to get what I need. I was just hoping someone knew how to control it without the work-arrounds.
Carstenem
yeah I think that's about it about this tool !
Carsten
www.asmtechbase.com
Erwin Edel
Gave up on that long ago and when I want to show those seams, I model them with single plane roofs, which I can connect together easily with CTRL + clicking an edge. Multiply with a spread at the proper distance does the rest.
Early stages I just show a vectorial fill.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
