Second arm of stair invisible in section
RobiLMan
Anyone knows why is my second half of stair´s arm invisible?
CosminF
Hi! My three possible guesses:
1. Maybe the section has a limited depth
2. Or your section settings are such that uncut elements do not show
3. you have a graphic override active that has the uncut lines with a white pen.
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
CosminF
The first solution worked thanks, but its not always available when editing stairs. Is there an exact point where i should aim?
CosminF
The first solution is linked to the section element in the floor plan, not the stairs.
So when you have a section marker on a plan, you could see the option there and adjust the depth of each section to your needs.
Setup info provided by author
