a month ago - last edited 4 weeks ago by Barry Kelly
Anyone knows why is my second half of stair´s arm invisible?
Solved! Go to Solution.
a month ago
- last edited
3 weeks ago
Hi! My three possible guesses:
1. Maybe the section has a limited depth
2. Or your section settings are such that uncut elements do not show
3. you have a graphic override active that has the uncut lines with a white pen.
a month ago
- last edited
3 weeks ago
a month ago
The first solution worked thanks, but its not always available when editing stairs. Is there an exact point where i should aim?
a month ago
The first solution is linked to the section element in the floor plan, not the stairs.
So when you have a section marker on a plan, you could see the option there and adjust the depth of each section to your needs.
