Views placed in layout a mile away from sheet?
Whenever I "save a view and place on layout" the view is placed litterally a mile away from where the sheet is. I have to zoom all, select everything, find the view then move it 5,000 feet back to where the sheet is.
Is this a known issue, or am I doing something wrong?
14 Replies 14
Djordje
Make sure that the layout you want to place the view on is current.
Then, a square will appear; it is a placeholder, whose center is the center of the view. Snap it to the center of the sheet - or wherever you want it - and that's it.
Now, if your view is defined miles off the origin, or if your model is miles off the origin, that might be the problem? Any merged or XReffed DWG?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
Snap it...
That's nice...Too bad there's no snapping for the drag-view-from-Navigator method.
James Murray
James wrote:
Djordje wrote:
Snap it...
Yeah. It really bugged me when I discovered that. Not a big thing, but it doubles a small effort and is certainly inelegant.
Where you notice it is in the detail sheets. If you drag multiple views onto a gridded sheet, they will fall into the cells automatically. Assuming you use an object in the detail window for the grid cell extents (which, IMO, you must), this is pretty slick.
But it doesn't work when you drag a single view! If the snaps worked, I might not miss it...
Altogether it puts us, again, right at 80%.
James Murray
Yep - do that.
Yep - do that, too. Then when the drawing vew is actually placed, it puts it several thousand feet away from the sheet.
This might be it. How do you know where the origin is? Can you re-define it? Or do you have to move the entire model closer to it?
Nope - single pln created by someone else - way back in ver 8, though. Could 10 screw up the origin point?
David Maudlin
Jeffe:
You need to move the model to the project origin. This can be done in one step by using the heavy marquee (works through all stories) surrounding the entire model to drag it to the project origin.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
heavy marquee
Don't forget: All layers showing and unlocked.
To restore the user origin to the project origin, double click the origin button on the Coordinate Box or toolbar. Zoom way out and you'll see it.
James Murray
Rod Jurich
James wrote:
/.......... Zoom way out and you'll see it.
Or, as I've found with the odd DWG where the origin is so far away. I set the origin from the coordinate box then using the line tool, draw a line with x,y set to zero and drag the rubber band into view. Then select all and drag to where you want the model placed.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Cool, thanks all.
