Wall Ends -- surfaces?
Geof Gainer
I can't seem to find where to change the surface color of a wall end to match the wall--thanks.
AC fan since v 7. Currently on AC 26 Build 5003 USA FULL Apple Silicon,. 2022 Mac Studio, 32G ram. OS X 12.6.2
The Wall End tool places one of several (GDL) library 'well end' objects.  So, like any other object, you need to select the wall end and open the object settings dialog (cmd-T).  Surface is under the 3D Representation panel. 👍
One of the forum moderators
AC 26 USA and earlier   •   macOS Ventura 13.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Which one?
They are all a bit different.
The one that returns wall skins (Returned End) should pick them up automatically and you can't set any surfaces.
The others all seem to have a "Surface Override" in the parameters.
Versions 6.5 to 26
Ah: "Surface Override", missed it
