2008-02-12 07:36 PM - last edited on 2023-05-25 06:12 PM by Rubia Torres
2008-02-14 12:54 AM
2008-02-14 01:16 AM
2008-02-14 02:43 AM
What is a temp file ?I should say temp folder. I created a folder named "temp" to extract my Object Library 10.lcf into. I then swapped the macro files, but I get stuck there with creating the updated library container file.
If you go to file->libraries and objects->create containerThis is exactly what happens. I cannot figure out how to incorporate the revised macro file into the .lcf.
you should see a window open that shows the loaded libraries
either as ordinary folders or .lcf files where you select what
you want to be converted to a library container file. What do you see ?
2008-02-14 03:12 AM
2008-02-14 07:06 PM
