2015-06-24
05:01 PM
- last edited on
2023-05-26
02:58 PM
by
Rubia Torres
2015-06-24 07:49 PM
2015-06-24 08:15 PM
2015-06-24 11:03 PM
2015-06-25 01:10 AM
2015-06-25 01:17 AM
Rlcosta wrote:Thanks for checking. Must be a US template glitch. I'll contact support.
Tried the demo of 19 for mac...no asterisks..
2015-06-25 05:32 PM
2015-06-25 08:17 PM
2015-06-30 03:10 PM
2015-07-07 11:50 PM
Ransom wrote:
Friends,
Admittedly, the asterisk is an undocumented feature. (There are others because we ran out of time.)
The asterisk indicates the first 48 surfaces by index. These surfaces (formerly materials) have been in ArchiCAD for so long that they have become a Graphisoft Standard. All the ArchiCAD Libraries going back to at least 4.55 depend on the character of these surfaces and default to them by index number.
So the asterisk indicates that the user should not change the essential character of these surfaces. I.e. don't make glass look like brick or all the window glass in the library will have brick surfaces by default.
However, all the surfaces can be edited to make them look better or even be renamed. Indeed, all the surfaces were reengineered for the two US 19 default templates in order to make them look much better in OpenGL and to make the OpenGL and CineRender results, match each other in terms of unit sizing and color.
BTW, another undocumented and incomplete feature is the colon at the end of composite names. We were developing an NCS wall label that would display whatever was added after the colon. That way, the user could simply add a letter or number code to the name and it would display in the automatic label. The key here was that the wall type, rather than its user ID, would drive the associated labels. Alas, our label did not make it through final approval. But we expect something soon.
