elle83
curved lower monolithic surface
Hi!
I'm modelling a monolithic stairs. The lower surface is curved, but I'd like it to be straight (like the red line). I don't understand which parameter I have to change.
Thanks in advance.
1 Solution
Lingwisyer
Guru
Since there aren't actually any winders, unlike in Barry's link, just set the landing to a flight rather than a winder.
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Go to post
9 Replies 9
Yes it is a problem and I wish something could be done about it.
The best I have found is to model the stair and then split the structure.
The flat underside height can then be controlled for winders and landings, but the flights will still have a bit of a curve to them on the underside.
But at least you are still dealing with one stair.
Otherwise you need to model each flight and landing/winder separately.
TIP: Initially create one stair so you can get the riser heights, then ALT-click to get the default settings, now make your individual pieces - each with the correct number of risers.
This will allow you to have flat undersides to the flights and the landings/winders you can set the height of a flat underside.
This is messy if you ever need to adjust the floor to floor height.
Here is a post where I mentioned the problem before.
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=66176#p294233
Lingwisyer
Guru
Ling.
elle83
Thanks to both of you. This time I can choose the simpler solution.
@Ling, may I ask you please how can I get the horizontal underside in the landing like your stair on the right? I get two separate steps with the same thickness.
Lingwisyer
Guru
The second landing thickness has been modified to include the first landing.
Step by step instructions (forgive the pun)
Go into EDIT mode and then select the higher of the 2 landings.
Now you can set the thickness of the landing to be what you want.
i.e. add the riser height to the landing thickness and the base will now match the lower landing base.
elle83
Thanks again to both of you, I'm new to this software and I'm still understanding how it works.
I'm not so new and still trying to understand somethings after some 20 years.
elle83
I guess the possibilities with software like this are endless. Like you with archicad, I still learn something new of autocad after more than 20 years.
Lingwisyer
Guru
Like so many of these big programs, the majority (common?) of users only know a fraction of it that is relevant to the work they do and maybe a tad more and even then, what they know maybe different to someone else who does the same work.
