deleting portions of composite walls
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-02-22 10:43 PM
‎2007-02-22
10:43 PM
AC 8.1 v2
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-22 11:06 PM
‎2007-02-22
11:06 PM
You could use Solid Element Operations, but it will require you to model a shape to use as a cutting form. Note that this will only work in section/3D, not in plan.
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-23 02:48 PM
‎2007-02-23
02:48 PM
how about using the niche window? it can have a depth of the skin you want to remove and whatever width you want...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-23 03:09 PM
‎2007-02-23
03:09 PM
TomWaltz wrote:Tom, is there a way to make it show up in plan view?
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-23 03:17 PM
‎2007-02-23
03:17 PM
Jere wrote:SEO's are notorious for only making changes in 3D.TomWaltz wrote:Tom, is there a way to make it show up in plan view?
The only way to make it show up in plan is to actually make different wall types, which really stinks.
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-23 03:25 PM
‎2007-02-23
03:25 PM
It is really pretty easy to duplicate the composite and change it, and does the job. You can easily split a wall, if necessary, and syringe the new composite to the area where it is needed. Much quicker than messing with Solid Element Operations, and if you are now, or ever will, need to run calculation (material list) you have the proper composite to key in.
It's really very easy, and once you build a good composite "library" you have it. You can always use the Attribute Manager" to apply elsewhere.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-26 08:25 PM
‎2007-02-26
08:25 PM
