how to convert thousands of CAD text to line or 3D text
Hello, I am making a feature wall with thousands of ancient Chinese symbols which is in CAD format, any quick way to convert them to line or 3D text in AC? (I tried explode but not working),
Thanks
1 Solution
mikas
I don't know a straightforward workflow for that either. But I have done it a couple of times though.
Print a pdf, use some capable enough graphics program to open that pdf - then convert text to paths, then save as pdf. Illustrator, Affinity Designer, InkScape or some other programs or dedicated converters will do.
AC: import pdf, explode pdf to fills, make complex profiles out of fills or use magic wand to make slabs if appropriate. Use complex profiles and/or slabs as needed. You can try copy-pasting between programs too, that might come out as pasted fills outright miraculously in archiCAD - but not necessarily.
It will be a tedious task though. And this approach might give you a pretty complex and big file eventually.
Maybe you'd be better off with printing it in multiple parts to pdf's and working that way, I don't know.
AC28, Rhino8+Grasshopper, TwinMotion • Mac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
Go to post
5 Replies 5
runxel
Sadly there is no way to do that. I also sometimes wanted to have this feature.
One option would be to use the text library object, but this is possibly a bit too cumbersome for you, since you would need to enter all text again.
Maybe there is an DWG import option do explode text - otherwise do it in Illustrator, which can read DWG files, too.
mikas
thanks guys
Hmooslechner
I have no clue about Chinese letters but i think its possible in an relatively easy way through scripting:
https://www.dropbox.com/s/4zlzc88mjub6sob/Text%20zerlegen%20und%20einzelne%20Buchstaben%20anordnen.pln?dl=0
in GDL (scripting language in Archicad) it is possible to extract single letters from a text-string. If you script a loop with geometrical steps, you can situate the single letters at any geometrical path-points within the library-object in 2D and also extracted in 3D.
In the Masterscript, You could extract the single letters this way:
! Textstile festlegen:
DEFINE STYLE Stil2D "fontType", TextGr, 7, 1
DEFINE STYLE Stil3D "fontType", TextGr*100, 7, 1  !*100= scale-factor in 2D)
!!!! String zerlegen und einzeln an einen Array übergeben:
!Länge:
Anzahl = STRLEN (Buchtabenfolge)
!! Zerlegung:  (STRSUB (string_expression, start_position, characters_number))
Dim Buchstaben[]
for i = 1 to Anzahl
	Buchstaben = STRSUB (Buchtabenfolge, i, 1)
next i
in the 2D-Script it could looke like this:
!!! Buchstabenfolge aus Masterscript einsetzen:
hotspot2 0,0
STYLE Stil2D
if Art = "gerade" then
		for i = 1 to Anzahl
			Text2 0, 0, Buchstaben
			hotspot2 0,0
			add2 a/10, 0
		next i
		del Anzahl
	else
endif
if Art = "Kreis" then
	Umfang = A*2*Pi
	Einzelwinkel = 360 / Anzahl
	rot2 Einzelwinkel
		for i = 1 to Anzahl
			rot2 -Einzelwinkel*i
			add2 a, 0
				hotspot2 0,0
			del 2
		next i
		del Anzahl*2
	else
endif
if Art = "Bogen" then
	Einzelwinkel = Bogenwinkel / Anzahl
	rot2 Einzelwinkel
		for i = 1 to Anzahl
			add2 a, 0
				hotspot2 0,0
			del 2
		next i
		del Anzahl*2
	else
endif
In the parameter-Script this line is needet:
values "Art" "gerade", "Kreis", "Bogen"
And in the parameterlist, all the needet parameters schould be present.
As i showed in 2D - it would be possible in 3D too... something like this:
hotspot2 0,0
STYLE Stil3D
		for i = 1 to Anzahl
				Text 0.05, 0, Buchstaben
			hotspot 0,0,0
			addx a/Anzahl
		next i
		del Anzahl
	else
endif
	Umfang = A*2*Pi
	rotz Einzelwinkel
		for i = 1 to Anzahl
			rotz -Einzelwinkel*i
			addx a
				hotspot 0,0,0
			del 2
		next i
		del Anzahl*2
	else
endif
	rotz Einzelwinkel
		for i = 1 to Anzahl
			addx a
				hotspot 0,0,0
			del 2
		next i
		del Anzahl*2
	else
endif
Thanks everyone here, i have finished the design product as below:
