make truss with my own profil
dear master,
i want to make truss with my own profil, thus this profil is not exist in trussmaker.
an archicad master has shown me his work, but he does't have any time to teach me how.
he didn't use add on (like cad image) . he just did maunally
i hope any masters would like to share the way to make the truss.
i sent the file (jpeg) that i got from him.
thx.
MrC
Hi endeperdian. Not sure which version of of ARCHICAD you are using, but you can model your truss using the standard beam tool and objects. Make a custom beam profile for the purlins.
You could also make each element a custom profile.
Make one truss and then select all and use the multiply tool to spread the trusses at the correct spacing.
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
thank you very much,
i'm using archicad 18.
i made the truss using beam with profil manager.
but my problem is
i couldn't trim it.
is there a way to trim or i should make the specific length truss without trim?
#sorry for bad English
MrC
Try using this object. it will save you time I think
BRITISH COLUMBIA
