modeling at rim of floor, edge of roof
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-10-01
09:26 PM
‎2023-05-23
03:08 PM
Rubia Torres
‎2008-10-01
09:26 PM
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-10-01 09:36 PM
‎2008-10-01
09:36 PM
Specific examples would be helpful. 2D or 3D is depending on the situation. For instance, we don't model studs but insert 2D Objects where needed in the wall sections. Parapet coping, eaves and rakes we model with Complex Profiles. Corrugated metal siding we would not model; unless it was useful to the condition under consideration.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-10-02 02:27 PM
‎2008-10-02
02:27 PM
Laura, how are you handling the corner of a raked end and the flat eave.
We have been using the Eave maker object for some time now. I tried using the complex profiles the other day and couldn't get that corner to join correctly. I did this using the beam tool.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-10-02 03:21 PM
‎2008-10-02
03:21 PM
cremsberg, i hijacked your thread and never offered suggestions, sorry!!
I would suggest using the joist beam object under 06 Wood-Plastic. it willl give you the options of a few different section cut displays. You may be limited by pens as far as display goes.
As for modeling the exterior, you could draw a short wall using the same material so it will blend or start your upper wall "below" the current story lheight to match
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-10-03 06:25 PM
‎2008-10-03
06:25 PM
Chris wrote:Well -- that's sort of hit-or-miss -- and usually results in resorting to SEOs.
