a week ago
In Archicad, when I select a 2D object individually, there is usually a 1-2 second delay before the toolbox appears. However, when I use the Arrow tool to select objects by area, the object description window pops up immediately. Why does this happen? I would like the screen to switch instantly even when selecting objects individually.
Operating system used: Mac Apple Silicon sequoia
Solved! Go to Solution.
Sunday
Hi Sangho,
check this thread: https://community.graphisoft.com/t5/Modeling/Apple-M1-Units-I-select-items-and-they-always-want-to-m...
If you have Magnet installed, you should close it and it should work well (I see you have an icon). I had the same issue on M3Max and this solution worked for me.
Best
Karol
Sunday
Hi Sangho,
Best
Karol
Sunday
oh my god!!! Thank you so much
it was solved immediately.
Sunday
Happy to help Sangho Ryu, real kudos to @furtonb 😎
Best
Karol
