2022-11-22
12:09 AM
2023-02-24
02:32 PM
Noemi Balogh
Hello all,
I have this issue in my Archicad file, where all my elements' snap guides in 3d view are offset. Has anyone come across this issue? I know it might be a very simple click, however I can't find out where this setting might be.
2022-11-22 02:21 AM - edited 2022-11-22 02:23 AM
Hotspots and bounding boxes not lining up is often caused by modelling far from origin. Alternatively it can be caused by a driver issue, in which case sometimes restarting AC will fix the issue.
Ling.
Note: This thread should not be in the sub "What's New?" Probably "Design"
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2022-12-01 12:59 PM
Hi @Sejal Chevli,
It does seem like a far from origin issue. Please refer to this article, it will help you find out if you are modelling far from origin and fix it.
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
