vertical lines under roof elements in 3D
Quirk
Does anyone have any idea as to what causes the vertical lines under the roof elements to occur in all of the View > 3D View Options > in the lower list (from 3D Details through to Simple Shading with Shadows) but not in any of the upper list vectoral options?  and how one can remove them from the 3D model? They make the renderings unreadable.
Thanks
 sequoip
AC 29 USA
macOS15.5
2.6GHz
2 ACCEPTED SOLUTIONS
Hello Quirk,
Did you try to clic on this icon ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
That is the 'Trimming Bodies' on screen view option if you want a name.
It does look like Quirk has turned that on.
It won't print.
Hello Quirk,
Christophe - FRANCE
It won't print.
