Our Community
Ask questions about this community and the platform.
Pop-up Command in Menu (Selecting three vertical dots) on Forum does not work.
Lee Hankins
Whenever I select the there vertical dots within my posts ir other posts, none of the commands within the pop-up menu respond. I am using Safari on macOS 15.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Noemi Balogh
Hi Lee,
There is a known issue with our platform and Safari, certain Safari updates break it, others fix the issue unfortunately. I know this is not the advice anyone wants to hear, but if you can switch to Chrome / Edge / Firefox, it could fix the issue for long term. In case of Safari, you might want to check if you can update to a newer version, but based on my experience it's hard to tell on which versions it is working and which versions it not...
Thank you for your understanding and sorry for the inconvenience!
Noémi Balogh
Senior Community Expert, Admin
Noemi Balogh
Hi Lee,
Noémi Balogh
Claudius
Finally got hold of a macOS 15 machine with Safari 18.3 to test and the three dot menus work fine for me in board and topic locations which I tested. Are you still facing problems with that today, @Lee Hankins?
Claudius Henrichs
German Community Manager
Leipzig, Germany
Lee Hankins
Hi @Claudius,
It seems to be working at the moment. The issue comes and goes with various macOS and iOS updates.
Lee Hankins
macOS Tahoe (26.0)
