Our Community
Ask questions about this community, the platform, and any technical questions.
Posting on Forums doesn't give sufficent "Label" options
Josh Verran
Not sure if this is the correct place to post this query/observation.
When ever I make a post, I want/have to add a label (great way to search later).
The only issue, is that you have to pick from one that already exists, but the options don't seem complete.
When you attempt to add one, you get a notification, "Correct the highlighted errors and try again.".
For example, below I posted a "Wish" regarding columns, "Columns" wasn't an available label, nor was "3D...".
Yet Beams and Objects are available.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare
LinkedIn | www.creativespace.co.nz | Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
2 ACCEPTED SOLUTIONS
13 REPLIES 13
Lingwisyer
Hero
Yeah... to go from unregulated labels to a short static list was a bit extreme...
Win10 | R5 2600 | 16GB | GTX1660
The right place for these discussions is the "Our Community" forum - which is where I've moved this topic.
The Graphisoft Community staff can answer the specifics and perhaps grant your request for additional labels.  It seems like an oversight that Beams is there yet Columns is not, as you say.
The reason for making labels static is to control them... since with uncontrolled labels, we were having insanely silly words being added as tags/labels.  Why would this matter?  Eventually these terms will be part of searches and subscriptions.  (I hope they will one day be a graphic tag cloud as well, but don't know about that.).
The choice of tags/labels is unique to each forum as well.  Please do post here if you find additional needs that don't exist that are generic enough that other users would want to use and/or subscribe by the same term.
One of the forum moderators
AC 26 USA and earlier   •   macOS Ventura 13.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Lingwisyer
Hero
I feel like I made a post about it somewhere, but I cannot find it... anyway, I feel like labels should be open but moderated before they become visible. So if you feel like a label is missing, you can added it and a mod can then vet it. Given we know that permissions can be tied to each of the community ranks, this can be added to that to reduce spam and abuse.
[New Label] => Alternative Label Suggestions => None Suitable? => Add New Label Button => [New Label Invisible Till Moderated]
That's because you couldn't give it the proper label. 🤣
I say that in jest, but it is actually true.
The list of fixed labels is only good if the list is sufficient.
I'll try to remember to bring this up at the next community meeting at the end of this month.
Versions 6.5 to 26
Noemi Balogh
Karl and Barry summarized the reason very well about the current policy of labels. Since your request is absolutely reasonable, I added Columns as a label to the Wishes board.
@Barry Kelly , @Karl Ottenstein - I noted this thread, added a reminder for the upcoming meeting.
Noémi Balogh
Community Expert, Admin
Erwin Edel
I mean, look at the archicad tools and add them all? This isn't exactly rocket surgery 🙂
The idea of being able to filter on tags is great, of course!
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Josh Verran
Thanks for the explanation guys.
If I come across any more I'll notify as suggested.
gdford
I rarely find a label that seems like a correct fit.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
Do you have any suggestions? Let us know and we can discuss updating the existing label sets.
Noémi Balogh
