2020-02-18
04:08 PM
2023-05-11
11:04 AM
Noemi Balogh
2020-02-18 05:23 PM
2020-02-18 05:28 PM
2020-02-18 06:13 PM
2023-04-05 11:24 AM
Has anyone found a good solution for this problem? There must be a way to break the connection to the created elements in Archicad permanently. So that if I reconnect to Grasshopper, the elements don't connect again, but are 'normal' Archicad elements. And I can use the Grasshopper script for some other elements.
@mikas : What kind of switch did you suggest? Inside of Grasshopper or just changing the layer in Archicad?
2023-04-09 09:06 PM - edited 2023-04-09 09:07 PM
You could try selecting all Grasshopper-created elements and make a copy of them. That way the copies will no longer be connected to and be dependent on Grasshopper as they will be new elements within Archicad with new GUIDs, so that should work in theory. You should try it though to see if it works I do not have Grasshopper right now.
2023-04-17 07:39 AM
Hi, thank you for the answer. I know that this method works, it is just very impractical. A baking button like in Rhino would be the way to go. Hopefully soon to come.
