2024 Technology Preview Program
Parametric design
About Rhino & Grasshopper and PARAM-O.
Creating hotspots in PARAM-O
Hi all,
Is there a possibility to create hotspots on certain coordinates directly in PARAM-O?
Thank you,
Oli
13 REPLIES 13
I do not agree, Param-O has some limitations in creating shapes but GH-Archicad live connection has limits works to Archicad also, better to use them both.
Hi, I understand that you will use GDL Shape but where will connect the node or just simply place it somewhere in the canvas? Thanks!
In the end what is your Objective?
ArchiCAD 9 onwards
That will make hotspot(s) only in 3D, not on the 2D floor plan view...
Is there a way to set hotspots that are visible on the floor plan view?
cuba
As far as I Know, you can only add 2d hotspots in GDL. This works very well in combination with param-o.
There is an excellent tutorial about hotspots on "Barking Dog Bim"
https://www.youtube.com/watch?v=b99b7HBqoiA
Apple M1 Max 32 GB Ventura
AC27
