Hi, I've been systematically converting our template to make use of Grasshopper, to speed up the drawing process. Since we do 400ish custom homes per year, cutting out a lot of the grunt work will make a huge difference.
I just noticed as I'm beginning to adapt electrical layouts (which we have a set number per zone type) there's no option for Lamps. Why is that? Did I miss something?
My use case would be filling a room with LED downlights, using Deconstruct Zone, Areas/centroids/boundaries and offsets.
Surely big commercial projects use this? or make fancy parametric lighting facades with schedulable Lamps? No?
I also noticed the newer "Equipment" category is missing also, when can we expect to see these items added, there is nothing on the roadmap?
![Pato99_0-1718627098737.png Pato99_0-1718627098737.png](/t5/image/serverpage/image-id/62370iD1C9FDCBC38023EF/image-size/medium?v=v2&px=400)
Versions 10 to forced subscription
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
