Project Management articles
Articles
Archicad as a Coordination Tool
Every now and then the question arises: how to use Archicad as a coordination tool. There are multiple workflows in which you can differentiate and compare the models of different disciplines. Let’s take a look at the following model where architectu...
Migrating Classifications
There are a lot of cases – even if it is not entirely intentional when you migrate projects. This happens when content made in an earlier version of Archicad is opened in a newer version. These scenarios can include: simple copy-paste from your old p...
How to optimize a project's file size
Although a project's performance is the most important, sometimes the large size of a file can be a problem. This article helps you learn what data is stored in a file and how to achieve a balanced BIM project that does not occupy more storage space ...
