Got a minute? We appreciate your feedback:
Graphisoft Learn survey
2D view reverts back to the previous view and falls into pieces
Tamas Gaspar
Affected versions: ARCHICAD 20 and previous versions | Windows, macOS | Severity: workaround applicable | ID: 211094
Note: This issue is fixed in the Update 5025.
Issue When zooming in/out, and using the Pan command with the Pan button or a shortcut on the keyboard, then placing or modifying an element, the 2D view can behave odd: the previous view appears behind the current one and the two views are interfering with each other as visible as on the screen shot above. Cause Panning with Pan command and with the middle-click on the mouse trigger different working methods in ARCHICAD, however the results look like the same. This why this issue doesn’t exist by using the mouse buttons. Solution There are two known workarounds for this issue:
  • Restart ARCHICAD to temporarily fix the problem.
  • Use only the middle-click to avoid the error appearing again.
Contributors
Version history
Last update:
‎2016-08-31 02:58 PM
Updated by:
Browse more articles
Back to articles
