Project data & BIM
Editing ID in schedules chrashes Archicad
Niranarch
When I edit window ID in schedule archicad crashes always.  Sent bug report.
any clue how to fix it?
Thank you
Niranjan
It shouldn't crash, but that doesn't help you much.
Make sure you have the latest update for 28.
Also be sure to follow up the bug report with your local support, take note of the bug number and ask them to investigate it.
Don't expect Graphisoft to get back to you directly.
I did the bug reporting. Have not taken the local support. I will do that.  I have installed the latest updates.
Thank you.
Setup info provided by author
