2024 Technology Preview Program
Project data & BIM
Fire rating/Acoustic rating is not showing in Door list
Vitaly O
Hi, is it possible that fire rating on plan will be also automatically visible in schedule for doors? As you can see, I have inserted values in door marker, added fire rating option in schedules , but in door list Fire rating column still blank, same for acoustic rating too.
Every time I have to insert those value manually, what I'm doing wrong?
Thanks in advance
Operating system used: Windows 19045.4170
Vitaly O
topic closed, i found an error(:
Hey, can you share the error? I have encountered the same issue but not the solution/error. Thanks
Setup info provided by author
