2004-04-22
01:44 PM
- last edited on
2025-01-29
05:25 PM
by
Aruzhan Hamar
2004-04-23 12:38 AM
2004-04-23 11:25 AM
Aussie wrote:Oki!
Mathome
you havnt said how you got the area.
It is possible to get the area of either side of the wall which of course are different (in most instances)
2004-04-23 01:17 PM
2004-04-23 02:35 PM
Matthew wrote:
Mats,
It's hard to say without inspecting the model but I am guessing that your calculation may not be reducing the wall surface by the smaller opening. I forget where it is now, but there is a setting somewhere about for a minimum opening size for reducing the calculation.
That only accounts for one square meter though. Regarding the six tenths of a meter; the only thing I can think of is perhaps the door is somehow being reduced to the actual panel size in the calculation.
2004-04-23 03:23 PM
mathome wrote:That is the rule in some places, mine included; I think it originates in DIN. You ignore openings that are less than one square meter of area in the quantities calculation.
I found it under "set up list schemes". The reduction was set to reduce wall quantities if an opening was larger than 1 m2 (heavens know why).
2004-04-23 03:29 PM
Djordje wrote:I think this has to do with the fact that there is no savings in materials with smaller openings. The scraps are too small to be significant. It's a different matter for heat loss calculations of course.mathome wrote:That is the rule in some places, mine included; I think it originates in DIN. You ignore openings that are less than one square meter of area in the quantities calculation.
