Project data & BIM
Interactive Scheduler - Combining attributes?
I've looked but was unable to find any information on this.
We have a zone tag with multiple lines for room names and were trying to figure out if it is possible to pull this information into a single parameter value so it can be used in interactive scheduler.
Any suggestions are appreciated.
Combine the parameters within the object master or parameter script. Make a text parameter called full_name, then:
full_name=part1+part2+part3
PARAMETERS full_name=full_name
Then list that parameter.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Thanks James!
Had the text combining to one string but didn't use the "Parameters" line. Works like a charm now.
