Project data & BIM
Schema settings
ananas
I have changed many settings in my Schema and now some rows appear that I can´t delete, because I don´t know where they belong even.
Any idea?
Operating system used: Windows 11 Pro 23H2
vlahtinen
There’s an option which adds an empty row before every headline. Check if that’s activated. You’ll find it under the headline settings in the side panel, "Überschrift" → "Einstellungen" in your screen shot.
vlahtinen
Yesss, you are right! Thank you.
Setup info provided by author
