Project data & BIM
Specify to move by X/Y value when importing IFC
cs_ryl
Hi all,
I'm wondering if there is an option when importing IFC model from consultants that allows you to move their model by certain X & Y value, instead of dragging them each time?
I know you can do it with place drawing from external tab but can't seem to be able to do it with IFC?
AC23 AUSTRALIA
MacBook Pro M1 2020 8GB Memory | macOS Monterey 12.3.1
2 ACCEPTED SOLUTIONS
No, imagine it as drawing. You can place in anywhere in your model and when you change the drawing itself it will not move in your model. It is same with hotlink module. You can place it wher you want and how many times you want. Model in the module has its own point of origin and when you move whole module you change position of this module point of origin relative to you model point of origin.
BIM Manager at SIEBERT+TALAŠ
www.sieberttalas.com
That's exactly what i meant.
And yes, it woud be better if there was an option to specifi X/Y/Z value to project zero before inserting hotlink. it can only be done graphically afterwards.
5 REPLIES 5
Lukas Zeleny
You can place IFC file as htlink module. You move it on the right place only once at the beginning and it will maintain its position afther updating with new IFC file version.
thanks @Lukas Zeleny
Wouldn't i have to move it in the hotlink file itself everytime when I receive updated models - because the consultant can't move their models which is why it would be handy to have that option when merging IFCs
AC23 AUSTRALIA
Right I think I know what you mean here @Lukas Zeleny
Instead of moving it in the original IFC (after opened in AC and either saved as IFC or as a PLN) it will be hotlinked in first, and then moved to the correct coordinates as established between consultants. This will help avoid having to move them again because the hotlink will remember where it's been moved to.
This would work - though somehow I still think it could be a good option to have where we could specify the insertion point relative to the project coordinates in X/Y/Z value.
AC23 AUSTRALIA
