Project data & BIM
Walls type schedule
silvermat
Hello everyone!
I am looking for the best way to create a schedule/legend with all types of walls I use in the project (or only for selected ones).
My goal is to create a table with ID, 2D view, and multiline custom text where I can write materials with detailed information about them.
I usually make it in the model on the lowest level, but I want to remove everything that is not my building from my model.
I moved the rest of my legends into Independent 2D view, but it doesn't work with walls.
There is an example of what I want to get (or something close to it)
5 REPLIES 5
cuba
Wich AC-version are you using?  Did you check out keynotes in AC28?
Apple M1 Max 32 GB Ventura
AC27
I have AC28.
How can I use keynotes in that way?
Hello Silvermat, 
I did some tests with keynotes, it is not exactly what you need but it is an option:
+ Benefits of the keynotes is that you can easily type in the text with enters for a correct layout.
+ The keynotes labels can be placed anywhere on a plan/elevation or even a worksheet.
- The keynotes do not have a preview >> makes them hard to line align with the 2d views
- It is not a schedule , no auto-update when you add a new element
Working with schedules:
You can add a property with the extra info you want to show (options/property manager)
+ display automatically new walls
+ preview can be aligned with the text
+ add text in the schedule itself
- not possible to make seperate lines, only full textblock without enters (other parameters will add columns)
Maybe someone else knows a better workflow
AC27
The lack of line breaks in schedule is such a large shortfall...
kuvbur
You can try to work around the lack of line breaks with a large number of spaces at the end of the line. Here is one example of solving the problem.
Structural engineer, developer of free addon for sync GDL param and properties
Setup info provided by author
