Project data & BIM
Zone shedule - sorting with zone categories
Ansis Zirnis
Hi, everyone!
I been using on and off ArchiCAD for 10+ years, last few years used Revit, but now when coming back to ArchiCAD (now 25 version), I found that my old way of sorting zone shedule doesnt work fully anymore (last time on AC17 it worked fine).
I use different type of zone category for zone types and floor types. If in shedule I dont filter out zone categories, it works fine (pictures below)
But when I start filtering by zone category (because I want only 1st Floor shedule, not whole building), it adds empty rows (when I uncheck merge items and select some of empty rows in model, it shows doors and windows).
In older ArchiCAD versions I didnt met such issues. How to get rid of this empty rows? If in criteria I add, that "element type IS NOT doors, windows and so on" it doesnt remove them. Maybe Im missing something obvious?
ArchiCAD file of the example is attached.
Thank you in advance.
P.S. After posting noticed that total areas count is messed up, it is most likely becouse I deleted most of the model, for lower file size. Please ignore that inconsistancy.
scottjm
You need to add brackets around your 2 last criteria as your have the or qualifier.
Without the brackets in your current criteria config it will filter a Zone or basically anything thing else.
scottjm
Damn, that was THAT simple and obvious. Thank you.
I somehow managed to ignore bracket using in criteria filtering as a whole, for all these years.
