Report a bug
Found a problem while using BIMcloud Public Links? Report it here!
This forum is dedicated to BIMcloud SaaS Public Links - Early Access. Interested in joining? Click here for further details.
Steel Shapes Library
ksjhawk
Does anyone know why my Steel Shapes Library is no longer acting as it normally does? Currently, I cannot make a size selection, only 40x999, and all of the steel section objects I've placed read as "Size not found Try new values or see MSA Steel.pdf". I think this started around when I updated my AC28 Library through the updates dialog.
I feel like I need a PhD to manage Global Libraries, Legacy Libraries and Embedded Libraries. I have created wall sections that now have missing steel sections, and the aforementioned text. I spend so much time everytime I need to fix a Library issue, I can't do my real work.
MacBook Pro Apple M4 Max 128GB ram
OS X 15.7.2
AC29 - AC6.5
1 REPLY 1
ksjhawk
Just realizing maybe this i snot the right place for this...apologies.
OS X 15.7.2
AC29 - AC6.5
